Minneapolis Moline Tractors Discussion Forum
Will a 585 bolt right in a 705
705puller
05-21-2005 10:38:38
My neighbor has a 585 motor for sale and I was wondering if it will bolt right in my 705 and if possible I was wanting to use the bottom part of the block that has the serial number and model on it so it looks like it still has the 504 thanks for any advice.
MIB22
05-22-2005 14:02:52
 Re: Will a 585 bolt right in a 705 in reply to 705puller, 05-21-2005 10:38:38
It will blot in if you use the adapter housing from a 4 cylinder G. You will still have clutch issuse to work out The 504 base and the 585 will not interchange the blocks have a different bolt pattern just change the serial number tags.
EdP
05-22-2005 06:16:35
No. All 585 had the smaller bolt pattern. The 705 has the larger bolt pattern.
