Minneapolis Moline Tractors Discussion Forum
MM R Headlights
A.J.Peterson
06-03-2005 19:03:06
When Was The Change From 7" Flat Lens To 5-3/4" Headlights On The R Model??? I've Seen 7" On Early 50's R Model But I Am Wondering When The Change Was Made... I Am Working On A 1951 RTU And I Have A Set Of 7" Flat Lens Headlights But They Look So Big Mounted On The Tractor... And I Want To End Up With The Correct Lights. Thank You,
A.J.Peterson
BMG
06-04-2005 19:51:39
 Re: MM R Headlights in reply to A.J.Peterson, 06-03-2005 19:03:06
AJ,
According to the parts book the headlights were changed starting with the 1951 model year. 1939 thru 1950 used the 7" flat lens lights.
Brian
Alan K
06-03-2005 20:56:20
I believe they changed them in mid 1950-early 1951. That is what I found out on the ZA-U models. I bet the R's were the same. They were still the reflector type but were the size of the sealed beams that were on the ZB UB GB models.
