Minneapolis Moline Tractors Discussion Forum
Is this block junk
1951 RTU
06-05-2005 13:34:03
third party image
Is this crack fixable or is it junk? Thanks in advance.
Curt
BMG
06-05-2005 17:19:07
 Re: Is this block junk in reply to 1951 RTU, 06-05-2005 13:34:03
Curt,
I'd be looking for another cylinder block. I've never seen one crack there. Usually where the cylinder meets the top, right at the edge but not right at the top in the middle. I would think it would be very difficult to repair.
Brian
1951 RTU
06-05-2005 17:24:27
 Re: Is this block junk in reply to BMG, 06-05-2005 17:19:07
Brian,
I think it froze in northern Minnesota @ about 50 below. I'm looking for a donor block.
Curt
BMG
06-05-2005 17:35:14
 Re: Is this block junk in reply to 1951 RTU, 06-05-2005 17:24:27
I usually see the outsides of the blocks bust before the top of the combustion chamber. You'd think the casting would be quite thick in that area.
Brian
1951 RTU
06-05-2005 17:41:21
 Re: Is this block junk in reply to BMG, 06-05-2005 17:35:14
I figure it either froze hard or maybe someone put cool water in an overheated engine.
Curt
Kelvin
06-06-2005 19:33:13
 Re: Is this block junk in reply to 1951 RTU, 06-05-2005 17:41:21
I think its junk. But-If you want to try to have it fixed, get in touch with George Miller (georgemillermachine.com) I think. He's in Maryland. He can do a lot with cast iron. It might crack again when it gets hot. The risk is yours.
