Minneapolis Moline Tractors Discussion Forum
M5 LP or any LP ---questions
Alan K
06-21-2005 19:04:18
Has anyone ever converted an LP tractor to gasoline? I have a chance to purchase one but it has 10A4206 and 10A4210 heads on it. The guy said it looses antifreeze but it isn't going in the oil and there are no external leaks. Cracked head or bad head gasket I'm guessing. Any problems with operation, like for pulling plow, disk etc.?
magic
06-26-2005 08:58:32
 Re: M5 LP or any LP ---questions in reply to Alan K, 06-21-2005 19:04:18
Please call me about the M5 LP. 217-938-4975
Andy2
06-21-2005 20:39:55
The heads that are on that tractor would make too much compression for pump gas. You would have to burn high octane to prevent pre- ignition. If you want to burn gasolene and use it in the field, 4209 would be the head you want. Either of the heads that are on it would work fine for LP but they should be a matched set. 4210 is a common M-5 LP head.
