Minneapolis Moline Tractors Discussion Forum
FINDING THE RIGHT HEAD GASKET
BOOGER
07-14-2005 18:49:23
I BOUGHT A UTU TRACTOR AND THE HEAD GASKET WAS LEAKING SO I PULLED THE HEADS AND REALIZED THAT THE PISTONS WERE .040 OVER. THE PART NUMBERS ON THE HEADS ARE 10A4230.I DID SOME RESEARCH AND FOUND OUT I HAD 670 GAS OR G1000 HEADS. WHERE CAN FIND HEAD GASKETS?
Intrac
07-15-2005 17:45:25
 Re: FINDING THE RIGHT HEAD GASKET in reply to BOOGER, 07-14-2005 18:49:23
What part no is on the blocks? A utu should have 10a149 blocks. Standard bore is 4.25. When the heads were changed were the block,s changed also.A M670 has a bore of 4.625. You need to check the piston dia. You already know they are .040 over. You can use a tape to measure this. The host of this site list a head set for M5 thu M670 part no HS 8323B. Check bore and block no. Good Luck.
Mopower
07-15-2005 07:53:39
Welters Farm Supply in MO is a good place to buy them and Lubbock Gasket in TX has been good to me too. Those heads you have are very good ones. It ought to run very well.
wgm
07-14-2005 19:12:54
Fel-pro makes what your looking for. Any independent parts store can get them.
