Minneapolis Moline Tractors Discussion Forum
UTSD hydraulic pump
Big Al's acres
07-19-2005 11:24:47
I have most of what I need to put hydraulics on my UTSD-M. I lack the pump! I also plan to install power steering and would like to use the lift cylinder. Can I use a slightly later Webster pump off a 6 cylinder diesel? Is there another hydraulic pump that can be retrofitted with out extensive macine work? Look over your junk and see if you can help me with parts or advice.
Thanks, Al
ILL John
07-19-2005 11:39:46
 Re: UTSD hydraulic pump in reply to Big Al's acres, 07-19-2005 11:24:47
Al, I haven't got it done yet, like most of my projects, but I'm going to install a Behlen power steering unit on my GTB, '49, when I install the hyd system. If you run the pressure hose to the p/s, then to the hyd system, it'll have the p/s power all the time and the hyd system will work also. Did this on a Brown Jet, it works great, only used a Charlyn p/s unit. John
