G 900 engine
Merle Pochop
08-31-1999 14:32:25
I have a G900 whose engine is stuck. When I removed the heads, I discovered sleeves and gaskets whose cylinder bore is larger then the sleeve OD. I was told the G900 was not originally a sleeved engine. Also, during disassembly, I found water in the cylinders. quick look shows no cracks. Whats the leakage path, and is the head gasket correct?
cody
02-08-2001 21:02:32
 Re: G 900 engine in reply to Merle Pochop, 08-31-1999 14:32:25
forgot to mention if the pistons were aluminum they could have seized up after it got hot
cody
02-08-2001 21:00:43
Moline never made a tractor with sleeves. yes the heads could be cracked or if the tractor sat for along time water can run through the muffeler and down through the valves and if the valves were open the water would have ran into the sleeves.
