Minneapolis Moline Tractors Discussion Forum
ZTU carb kit
Alan CA
09-11-2005 11:56:23
I'm looking for a carb rebuild kit for a ZTU 38'. It's a Marvel Schebler TRX 12 Model TR
Tex Aggie
09-16-2005 07:41:25
 Re: ZTU carb kit in reply to Alan CA , 09-11-2005 11:56:23
There is a place in Indiana called Motec Engineering. I had the same carb, no pieces...totally corroded up. All I had were the two carb halves. i sent it to them, and for less than 50 dollars, it was sent back to me, painted with all new parts, with the bill enclosed. they also do water pumps.
Kelvin
09-11-2005 12:20:49
Alan, I've never seen a carb kit for those carburetors. Check with Matt at Motec engineering.
765-963-6628.
Those carburetors were pretty simiple. If your float valve is still good, all you really need is a new gasket and you might be able to make one from gasket material.
Kelvin
09-11-2005 12:22:48
 Re: ZTU carb kit in reply to Kelvin, 09-11-2005 12:20:49
I correct myself: If the throttle shaft is fairly snug and it has a good seal, and if the float valve seals o.K. then all you really need is to clean it up and make a gasket for it.
Alan CA
09-11-2005 12:33:54
 Re: ZTU carb kit in reply to Kelvin, 09-11-2005 12:22:48
Thanks Kelvin, I'll do that, clean up and put new gasket on. Still trying to figure out why my ZTU won't fire. Got it not running and it's not stuck, have good spark, so wish me luck.
