Minneapolis Moline Tractors Discussion Forum
MM pump motor?
BCnT
10-04-2005 20:42:09
howdy yall...new here...got a question about a small MM engine i'm gonna go look at this weekend...guy says only thing on it is 206A and bore and stroke is 3&5/8 X 5 and from pic its a stationary engine with a double pulley...not sure if its reduction gear or direct drive
motor is stuck so i'm wondering if parts still available fairly easy or is it another boat anchor
thanx
chuck
Kelvin
10-05-2005 09:23:40
 Re: MM pump motor? in reply to BCnT, 10-04-2005 20:42:09
Rings, beargings up to .020 undersize are available. Pistons as well. I've used bearings for a jetstar in a similar L-head 206, so don't let anyone tell you you can't get main bearings. NAPA has a pretty good gasket kit. The big issue is how badly stuck? The blocks can be bored oversize but not by most auto machine shops because their equpment can't bore a blind hole.
BCnT
10-05-2005 10:40:30
 Re: MM pump motor? in reply to Kelvin, 10-05-2005 09:23:40
i'm gonna pull plugs and see if its rusty water or barnacles...if its the latter i'm comin home empty.
thanx
