Minneapolis Moline Tractors Discussion Forum
g1000 vista locked up
4478
10-16-2005 11:05:50
got a g1000 vista. has been sitting 20 years, got it running but when I put it in gear and let off the clutch it wants to stall. is the ampli torque locked up or something? thanks
Greasey Hand
11-18-2005 07:44:00
 Re: g1000 vista locked up in reply to 4478, 10-16-2005 11:05:50
Brakes are stuck to the plates, take them apart, they will be like welded to the steel plate,
get them loose & sand blast them clean.
SWMolines
10-16-2005 13:29:56
If you have not been able to roll the tractor at all, it could be brakes are corroded and locked up. If you loosen the bolts on the brake covers and smack the covers with a hammer, they usually break loose.
Harrold Rhodes
10-16-2005 12:56:56
I don't think it will be the torc. Could be the bearings in the tranny or on the rear axles. I would also check and see if it has gotten in two gears.
