Minneapolis Moline Tractors Discussion Forum
LP heads / gas heads
Alan K
11-01-2005 20:27:35
Found an M5 that was originally lp and had a carb put on it and was run on gasoline. The heads are a 10A4209 and 10A4210 (one of each). What heads can be used for gasoline? According to the parts book 10A4209's would fit our elevation, in southwest MN. Would this be correct? He had said it was losing coolant, not visibly, not going in the oil, I am betting it has a cracked head. ?
ejr-IA.
11-05-2005 19:35:39
 Re: LP heads / gas heads in reply to Alan K, 11-01-2005 20:27:35
We have ub's with 336 with 4206 heads on gas.06 heads are 9.65 to 1 comp.10 are 8.0 to1.
Alan K
11-02-2005 18:21:05
Looked at the numbers on the heads in better light and one is 10A4206 and 10A4210. What would be needed to run on gasoline? Not leaking coolant out of waterpump though.
kelvin
11-02-2005 09:42:40
4209 are for gas 4210 are lp.
Jerry Cent. Mi.
11-02-2005 04:42:47
Coolent can go thru the water pump also.
