Minneapolis Moline Tractors Discussion Forum
First MM
36 A
01-01-2006 19:41:04
I bought me what i think is a ZAU not sure i havn"t got it home yet.It run i guss and needs tires. don"t they all.I"ll be asking some ?? in the future.One thing can i flip hte ring gear or will need to find one.Thanks 36 A
Jerry Cent. Mi.
01-02-2006 12:38:23
 Re: First MM in reply to 36 A, 01-01-2006 19:41:04
I have flipped several starter ring gears. Use a die grinder and a thin disc and add a chamfer to each tooth. Make sure that you know which side of the tooth to chamfer. I started a charcoal fire in the bucket of the front end loader and put the gear in it until it was heated up until it was blue and dropped the gear on the flywheel.
36 A
01-02-2006 09:04:40
I"ll take a good look at it when i get it home.Can"t wait to start.
Kelvin
01-02-2006 05:57:09
Pretty sure the teeth on the ring gear are beveled on only one side. but since it only has 2 dead spots, you might be able to get the ring gear off and turn it 1/4 turn.
