LP gas heads
Andy
10-06-1999 16:06:09
I recently purchased a UTS with LP heads and maifold and it burns gasoline. The compresion is higher and it has been bored out .125". I am wondering if there os any thing I shold be careful of when I am using it or working it hard.
Mike
10-07-1999 17:02:03
 Re: LP gas heads in reply to Andy, 10-06-1999 16:06:09
Do you know what the compression ratio is? What is the head casting number? Knowing this number, we should be able to figure out the compression ratio. I'm thinking that its probably around 9.5 to 1. If this is the case, your not going to do anything to hurt the engine, it will just make a little more horse power. If you want to e-mail me the head numbers, I will look up the compression ration for you.
Good Luck Mike
