Minneapolis Moline Tractors Discussion Forum
UTU year?
BJM
01-10-2006 11:38:54
Purchased my 1st MM on 1/06/06. A 1952 UTU? The serial # is 01920220.Will need some parts, grill possibly left fender. Any help or dialog will be much appreciated. I live in NW Iowa. BJM
GaryK
01-10-2006 11:57:19
 Re: UTU year? in reply to BJM, 01-10-2006 11:38:54
I believe the number that you provided is the engine number. The S/N list that I use shows this to be a 1952 engine. The tractor serial number should be on the right side on the transmission case. The engine number is on the engine block. This is a common mistake. If you get the tractor #, we should be able to figure it out for sure.
BJM
01-11-2006 08:40:58
 Re: UTU year? in reply to GaryK, 01-10-2006 11:57:19
I saw that tag but couldn't get any #'s off of it. I used a pencil eraser and I found the # 04300114. Any good ideas on getting the rear axle nuts loose, I have sprayed them for 3 days w/ pentrating oil and used 3/4" drive breaker bar and socket with a cheater bar, just bends the breaker bar?? Thinking of using heat next.
GaryK
01-11-2006 10:30:06
 Re: UTU year? in reply to BJM, 01-11-2006 08:40:58
BJM:
Can you confirm on the nameplate (where the SN is at) that it is a UTU or a UTE? If those axle bolts give you too much trouble, I'd be interested in buying it.
BJM
01-14-2006 05:43:26
 Re: UTU year? in reply to GaryK, 01-11-2006 10:30:06
GaryK,
Thanks for the info. As for selling, E-mail me.
GaryK
01-11-2006 09:11:50
BJM:
My reference shows SN's that begin with 043 to be UTE's. Further, SN's between 04300001 - 04300265 were UTE's with 6V. Further yet, SN's between 04300112 - 04300261 were 1952 models. It would appear that there were 150 of these built in 1950 and yours was the third. That's what my reference shows anyway. Good luck with the bolts. Maybe someone else can help.
