Minneapolis Moline Tractors Discussion Forum
5-star diesel
B Ballou
01-13-2006 10:03:20
I recently purchased this tractor with a stuck motor. A mechanic pulled the heads and two cylinders were really rusty. It has a 336 diesel engine. Does anyone know where you can get a replacement engine or a guess on how much it would cost to go ahead and fix this one? Thanks Brad
Troy Rickert
01-14-2006 12:16:07
 Re: 5-star diesel in reply to B Ballou, 01-13-2006 10:03:20
We have parts for the 336 diesel .
Rebore kit 4 5/8" standard bore is $450.00
Rebore kit .030 oversize is $450.00
Rod Bearing (4 req'd) is $33.00
Main bearing set is $165.00
Head Gasket set is $120.00
conversion gasket set is $100.00
oil pan gasket set is $14.00
Hope this will help you from www.rickertimplement.com
Kelvin
01-13-2006 17:15:24
How much wear on the other cylinders? I have had the rusty cylinders on gassers re-sleeved before. Mid-late '90's price averaged $100 per hole to sleeve and bore back to fit my pistons.
bALLOU
01-14-2006 14:05:22
 Re: 5-star diesel in reply to Kelvin, 01-13-2006 17:15:24
Thanks for responding, the other 2 cylinders look good.
