Minneapolis Moline Tractors Discussion Forum
Info...stroking a ZA ???
770
01-22-2006 07:21:06
A friend of mine bought a ZA Moline that he wants to set up for pulling. He was told that you could stroke the crank 1/2" and use ZT rods??? OR any other ideas??? How much money approx to stroke a ZA crank??? Thanks for any ideas.....
Augie
01-24-2006 09:26:05
 Re: Info...stroking a ZA ??? in reply to 770, 01-22-2006 07:21:06
How much HP is he looking for?
770
01-24-2006 13:52:51
 Re: Info...stroking a ZA ??? in reply to Augie, 01-24-2006 09:26:05
I know some of the people he pulls against have wc's with about 50 horse. I suppose the more the better.
Augie
01-24-2006 20:53:35
 Re: Info...stroking a ZA ??? in reply to 770, 01-24-2006 13:52:51
You can get 50 without working on the crankshaft.
5.5" stroke should get you over 60 and can be done without much grinding. The right parts and 6" stroke should get you up around 70, takes a bit of work to fit. 6.5" stroke will fit if you're creative and want to spend some $$$.
HP/CI out of a side-valve Moline engine will never match what you can get from an overhead valve setup, but they will lug like nothing you've ever seen.
770
01-25-2006 14:43:17
 Re: Info...stroking a ZA ??? in reply to Augie, 01-24-2006 20:53:35
I will pass the info....Thanks....
