Minneapolis Moline Tractors Discussion Forum
Add'd power pistons
1031D
01-26-2006 20:24:18
I am looking for a set of M&W pistons for a ZAU, most likely 3 3/4" bore. Does anybody have any? I know of a junk yard with some, but they are not marked as to what they fit. How would I be able to tell? Is the wrist pin the same distance from the top of the piston? Is there a casting number I should look for? I bought different blocks for my Z and they are pitted moderatly from about halfway down the cylinder to the bottom, and I'm thinking of getting them bored. These pits shouldn't hurt it too bad if I run the old 3 5/8" pistons, will they? I'm guessing the deepest pit is about .025 deep, and they look like someone dotted the cylinder with a pen. The reason I was asking if it would be okay to run them is because the bores measure 3.626 and the pistons measure 3.623, which is still in spec. I don't think honeing will remove them.
