Minneapolis Moline Tractors Discussion Forum
9 bolt hubs for a U
Bencie
02-02-2006 14:31:58
Does anybody know of another tractors 9 bolt hubs that will fit a "U"? Or options on making some without going with weld on hubs.
Jeff Zabel
02-06-2006 18:27:23
 Re: 9 bolt hubs for a U in reply to Bencie, 02-02-2006 14:31:58
I have what you need,M/W hubs 9 bolt off a Case 830 3" axles 3 3/4" U bolts to clamp too axle an 9 studs ,nuts to match on each hub. 920-867-3386
Joel H.
02-05-2006 13:39:49
M&W made 9 bolt hubs for 3" axles. I have a set on my U.
ejr-Ia.
02-03-2006 13:59:27
Use a 3010 jd with a shim.
Mopower
02-03-2006 06:33:23
Oliver Super 88 hubs are close, but require boring out to fit. I will be producing manufactured 9-bolt hubs by mid to late summer if all goes well. They are keyed & will slide on. Either clamped tight or held with a set screw.
rubenstien
02-06-2006 13:54:56
 Re: 9 bolt hubs for a U in reply to Mopower, 02-03-2006 06:33:23
mopower how much power will they hold b/4breaking talking 250 hp maybe do you have weld ons
Mopower
02-07-2006 04:55:51
 Re: 9 bolt hubs for a U in reply to rubenstien, 02-06-2006 13:54:56
A similar setup (not as thick) was used on a 200 h.p. machine a few years ago. Mine will be a little more beefy. A weld on version would be easier to make actually. I am planning on both now. Not sure when I'll have something going. E-mail me and I'll send you an early 3D picture concept.
Angus
02-02-2006 18:09:33
The best thing to do is take the moline hub right off the axle. Get yourself a nine bolt hub of of a farmall h (thats what I used). Just make sure it has a key way. Mine slid right on, I clamped it down, and it has been doing me good for the past year! So much easier than milling your current one. Email me if you need more help.
Andy2
02-03-2006 05:12:18
 Re: 9 bolt hubs for a U in reply to Angus, 02-02-2006 18:09:33
A U has a 3" axle, I'm pretty sure an H is 2.5"
Angus
02-04-2006 16:47:02
 Re: 9 bolt hubs for a U in reply to Andy2, 02-03-2006 05:12:18
well whatever ever I used was from a farmall...and its working great.
mm-r47
02-02-2006 17:10:35
I know who will do them call me.
SWMolines
02-02-2006 15:05:25
Have your MM hubs machined down to the 9 bolt size.
