Live power unit on MM U
Slo Mo
10-16-1999 05:55:38
I have a live power unit on a U, and am wondering how much trouble it is to change it over to a band brake? The other side already has a band brake on it. The power unit doesn't work, and the disc brake doesn't seem to work as well as a band brake.
Frank w
10-22-1999 21:08:00
 Re: Live power unit on MM U in reply to Slo Mo, 10-16-1999 05:55:38
I revamped a hand clutch on a UB. I think the
same process would work , call if you would like
to discuss..... ....612-874-0878
Joe
10-16-1999 07:08:40
It should be easy. Find a parts tractor with the band brake. It should unbolt/slide off the differential shaft. Do the same with the live power/ brake combo on your tractor. Replace it with the band brake. If you need a band brake let me know. I cna probably help.
