Minneapolis Moline Tractors Discussion Forum
electrical Moline G VI
Alan Thompson
02-25-2006 08:20:51
I bought a 1959 Gvi and don't understand the battery hook up. It is now hooked up as positive ground. Is this right or has something been hooked up wrong. What damage could this do to started.
Alan Thopson
03-01-2006 11:37:58
 Re: electrical Moline G VI in reply to Alan Thompson, 02-25-2006 08:20:51
The Gvi I bought cost 1850.00 and is bear back. It came out of colorado and has a hammer hitch. How hard is it to change the seals on the valves in the bottom of the tank. Is there any way other then draining the tank on a LP. My seals are leaking and there is about 20% in the tank.
GOT JUGS!!!
02-27-2006 14:09:42
you can hook it up - ground it wont hurt it it will show discharge on the amp gauge just swap the wires on the amp gauge and it will show charge. it worked on mine anyway
John in Utah
02-26-2006 19:40:01
I just picked up a MM GVI about 1 year ago. How many batteries does yours have? Are they hooked up in series? What did you pay for it or do you disclose that? Do you have any pitures that you can post or email me? Thanks John in Utah.
Alan thompson
03-01-2006 11:40:29
 Re: electrical Moline G VI in reply to John in Utah, 02-26-2006 19:40:01
My has been changed to one 12 volt battery.
matchew
02-25-2006 09:11:26
Most MM's back then where positive ground with generators. No damage will be done be starting the tractor. If you convert to an alternator, you will have to change to negative ground.
