Minneapolis Moline Tractors Discussion Forum
Boring U blocks
Alan Thompson
03-20-2006 09:25:18
I have a 52 U that was stuck. I got the pistons out and found a bad spot in two jugs. Machine shop says I need to bore out to 4.5 to clean up. Can they go out to 4 5/8 and still have good walls or should I get different blocks and pistons.
travis in il
03-24-2006 08:39:52
 Re: Boring U blocks in reply to Alan Thompson, 03-20-2006 09:25:18
Dan in IL 618-401-2386
ejr-IA.
03-20-2006 10:32:22
You could sleeve it and stay with your pistons.The 45/8 bore was used on the M5 making it a 336 cid thicker blocks.I think you can go 60 overbore on the blocks you have.
MMdude
03-20-2006 14:08:18
 Re: Boring U blocks in reply to ejr-IA., 03-20-2006 10:32:22
You can bore the blocks out to just short of 4.5 inches safely. Welter's in MO sells a set of pistons that is like .060" under 4.5 inches. They worked well in an my friends engine. His motor had 1/8" overbore with a stuck engine and had to bore it out to this size to clean it up. It runs very well and he did not have to buy blocks!
