Minneapolis Moline Tractors Discussion Forum
Questions about ZAU
36 A
03-29-2006 18:53:09
1 the narrow front the steering wheel has about 1/2 turn of play and i noticed the tires moving sideways.The shaft and nut are sticking below the center section? 2 one of the breaks are very touchy and locks easy and don"t look oily. 3 witch spark plugs does this thing take,i asked and somebody said 386 autolite but the shank is to large. 4 The hydro box under the gas tank where the lever hooks to the shaft is stuck need some info on the hydrolics. This tractor is a horse of a different color for me andneed to get a manule for sure.Thanks Mark
Kelvin
03-30-2006 07:05:13
 Re: Questions about ZAU in reply to 36 A, 03-29-2006 18:53:09
The spark plug you need is a Champion J-8 (The long J-8) or equivalent if you hate Champion plugs.
Unless the axle is loose on the shaft, that nut on the bottom of the steering gear is probably tight already and won't remove any play.
there is a big nut around where the shaft from the wheel enters the steering gear. If everything is O.K. inside-not broken or worn out-this is the only adjustment. You can take the radiator off the and look inside the steering housing.
I don't know what the problem is with the hydraulics. The shaft runs all the way through the housing and works the control valve spools in the cover on the other side of the reservoir.
