Minneapolis Moline Tractors Discussion Forum
MM 11A? disk
1 Dollar
04-20-2006 19:21:29
I think I have a 11A disk. I was wondering if anybody could confirm this of maye have some pictures? If you search "old disc" in the implement photos section the you can see it. I dont have the back sections for it. Thanks for any help.
Alan K
04-21-2006 21:06:06
 Re: MM 11A? disk in reply to 1 Dollar, 04-20-2006 19:21:29
I believe it is a 12B possibly. The 14B had a different hitch. The 11A was the first tandem disc MM had as far as I know. The 11B was similar to it. They have wood bearings in them. I have a 11A and a 14B MM discs for sale. Hope this helps. I have pictures in literature if you need info on your disc.
1 Dollar
04-22-2006 18:46:12
 Re: MM 11A? disk in reply to Alan K, 04-21-2006 21:06:06
I have it all taken apart right now and I am going to just replace the broken discs even though they are all terrible. $13.12 X 20 is $262.40 which is about 190 more thatI wan to spend on my DAD (dick around disk) It does indeed have hardwood bearings in it that are decent. I dont have the back half so it is pretty easy for my JD A to pull it. I was just planning on liberally applying rustoleum primer and then spraying it in MM red. Those pictures would be nice. If you can you could just send them to my email or something. Thanks for the reply.
Alan K
04-26-2006 06:20:44
 Re: MM 11A? disk in reply to 1 Dollar, 04-22-2006 18:46:12
If you are going to replace the blades or some of them, try a salvage or junk yard to see if you can match up some good used ones. You might find some, might..... that are similiar, and would be cheaper. The old JD straight disks are about the same.
