Minneapolis Moline Tractors Discussion Forum
FWA 'S
BHA
04-23-2006 07:04:24
Were there any Jetstar3 or U302's built with FWA(4 wheel drive)? I have seen pics of a 504 so I know some 4cyl FWA tractors were built.Was this the same FWA parts as the bigger G tractors?I have read that the front axle were usually military surplus,what about the transfer cases were they adapted to the tractors or made for moline?Final question. How hard would it be to build your own?Thanks Brad
Bobbi
04-25-2006 12:58:22
 Re: FWA 'S in reply to BHA, 04-23-2006 07:04:24
Not too sure on the factory U302 or Jet-Star 3 FWA's, some might have been factory, but others were dealer conversions. They used the same basic equipment as the M504. These axles were the Elwood military surplus axles, but the transfer cases were made specifically for MM's with the M504 cases being completely different than those on other tractors. The early G-700's (all G704's and early G706's) used the Elwoods, but most of them used the Coleman(Late G706's and all G708's). As far as building your own, good luck finding a transfer case. I don't think it is as easy as one might think to put one of these together unless you have the parts on hand. Moline mainly made two 4-cyclinder FWA's according to production records, M504's with the Elwood front end, and M604's with the Coleman front end, both of which are extremely hard to find. I hope this helps, Bob
