Minneapolis Moline Tractors Discussion Forum
M5 Hyd oil and steering question
Alan K
06-12-2006 23:33:48
What is the best oil to use in the hydraulics and the rear end on an M5 MM. Do have some steering trouble with it but it has been sitting so maybe it will loosen up...sometimes its there alittle and others not, or is that normal?
The REAL Kelvin
06-14-2006 07:13:29
 Re: M5 Hyd oil and steering question in reply to Alan K, 06-12-2006 23:33:48
The correct (modern) fluid should be Dextron III. I understand some guys change over to Hytrans so it works with their other tractors and have no problems.
I would suggest you check your priority valve in the pump to see if you have 600-750 psi or more going to the steering.
