Minneapolis Moline Tractors Discussion Forum
temp gauge for GB LPG
Bassndeere
07-14-2006 19:34:56
Hello,
Anyone got a source for a new tempature gauge with the long capulary tube 84" plus long? Any luck going to an aftermarket electric gauge?
Thank you,
Don
bassndeere
09-17-2006 15:37:02
 Re: temp gauge for GB LPG in reply to Bassndeere, 07-14-2006 19:34:56
Thanks for all the advice. Picked up the correct temperture gauge from Welter's Farm supply. Their GREAT people to do business with. NAPTA would not anwser me on their gauge.
Tony Larson
07-18-2006 13:59:36
Just finished going thru a "56 GB and ran into the same problem! I purchased a 72", which would not work in the proper location. Just to get by till I fine the right length, I put it off the hyd. tank. Not the best, but at least there is something to read.I"m going to check with the Napa store here in town.
Curt Cooke
07-17-2006 07:17:11
I have a GBLP and I bought a gauge from Antique Gauges that works fine. I don't recall it having such a long lead though. 84", are you mounting it in the stock dash? Where are you attaching it to the engine. I don't think it should have to be 84 inches long.
bassndeere
07-17-2006 16:48:22
 Re: temp gauge for GB LPG in reply to Curt Cooke, 07-17-2006 07:17:11
Hello Curt,
Thank you for the information. I am mounting the gauge in the stock dash location. The capulary tube runs down the left side of tractor, up between hdy. tank and engine block. over to the right side and sensor is inserted into the water manifold between valve covers and exhaust manifold. The orginal had a tube length of 84" but 96" would be better. Is there a different mounting location? The water at that location has already been thru radiator.
Thank you again,
Don
Shawn W
07-16-2006 09:42:39
Hello
I think we got ours from NAPA, its a stewart waner gauge and you could get it with a 10' long lead, think they ordered it for me and had it the next day. its been a couple years but im sure napa could help you out. of course the drawback to it is its not a MM gauge and it has numbers on it instead of the colors and cold run hot.
Shawn
bassndeere
07-16-2006 11:45:08
 Re: temp gauge for GB LPG in reply to Shawn W, 07-16-2006 09:42:39
Thanks Shawn, but the longest one I've been able to locate is 72 inches. Working toward an electric. Problem with that is positive ground, don't know if it will work or just short itself out. Thanks for the help, Don
Shawn W
07-16-2006 13:24:41
 Re: temp gauge for GB LPG in reply to bassndeere, 07-16-2006 11:45:08
OK, well good luck finding something.
dont know about an electic one, but i do know that i cant make a tachometer work on positive ground, fried one and now it wont work at all.
if you try it, let us know what happens.
Shawn
