Minneapolis Moline Tractors Discussion Forum
M602 has no power
baffled
07-17-2006 08:02:46
I have a 602 and replaced LP reg. with new beam made to replace Ensign and Put on a new head. Runs good but has no power under load .Any suggestions.-Checked fuel flow- Do not have water on reg now. Never had to have with old Ensign.
JW/NEOK
07-17-2006 21:29:31
 Re: M602 has no power in reply to baffled, 07-17-2006 08:02:46
You will have to have water to the vaporizer/regulator before you can run LPG on liquid to get maximum power.
baffeled
07-18-2006 07:41:58
 Re: M602 has no power in reply to JW/NEOK, 07-17-2006 21:29:31
Water does not seem to make a difference. Reset the valves and does not seem to make a difference
moline
07-19-2006 18:39:43
 Re: M602 has no power in reply to baffeled, 07-18-2006 07:41:58
Does the new regulator have a vacuum line from the intake to move the diaphragm in the regulator,did it crush the line right at the farrels when you installed it?If it does not have a vacuum line to the reg it uses the air cleaner oil resistance to move the diaphram.You may not be moving the needle far enough off of the seat to get enough fuel to her.The regulator may have a hole in the case to let air in on the opposite side of the diaphram,if the hole is plugged or painted shut,the diaphram will not move enough.Moline
