How do I find out what model U I have ?
Larry
11-21-1999 18:29:41
I just bought a MM Model "U" tractor. But I don't know if it could be a "U", "UT", or whatever. I would like to find out what model exactly, and what size or type engine it has.
Bill Becker
11-22-1999 07:26:21
 Re: How do I find out what model U I have ? in reply to Larry, 11-21-1999 18:29:41
You can tell the type of "U" by looking at 2 things - the front end and the clutch. If the tractor has a hand clutch, it is more than likely a "UT". The models with a foot clutch were designated with a "UB".
The following front ends would be designated in the model number as well:
UTU, UBU Narrow front end, dual wheels
UTS Wide front end, fixed width
UTE, UBE Wide front end, Adjustable width
UTN Narrow front end, single front end
UTC Wide front end, High crop
All of these models came with a 283 4cyl engine with a 4 1/4 X 5 bore & stroke.
The serial number can be looked up at the Minneapolis Moline Home Page
larry O.
11-22-1999 03:27:57
Look on the right side of the transmission case for name & model tag. Has a 283 4.25 x5 motor.hope this helps.
