Minneapolis Moline Tractors Discussion Forum
Z question
deereman_39
08-31-2006 16:39:20
just got a pair of z molines with the 206 engine. was wondering what are some engine build-up possibilities. would like to pull it in either the farm class or div III. thanks for any help
K.Koehler
08-31-2006 20:12:38
 Re: Z question in reply to deereman_39, 08-31-2006 16:39:20
Dont know the exact div. 111 rules but know I get right around 45 HP out of my za with 1/8 inch over bore and a head that is welded up like a propane head would be shaped. Still a work in progress nothing is done in top end in way of valves or even cam.manifolds are still stock to. dont know if this helpes any but thought it might.
RZZZ
09-02-2006 06:40:22
 Re: Z question in reply to K.Koehler, 08-31-2006 20:12:38
what did you do the fuel system? what RPM's you run? Thanks Mr RZ
K.Koehler
09-02-2006 07:46:52
 Re: Z question in reply to RZZZ, 09-02-2006 06:40:22
carb has bigger vanture still running gravity feed on fuel to. RPMs are right about 1800 to 1850 some times there turned down father thow really dosnt do much engine lugs really well.
Augie
09-02-2006 20:01:54
 52@560 in reply to K.Koehler, 09-02-2006 07:46:52
On the local AGCO store dyno is what I'm getting out of the 206 in my R. Pulls down to 56@450pto.
Stock stroke, Welters' 3.810" pistons, Berry cam, stock carb and manifold.
That ain't enough for DivIII.
