Minneapolis Moline Tractors Discussion Forum
5 star PTO
AC
09-17-2006 18:07:26
Is there some kind of trick to getting the PTO out? Does it come out the front or back? I have the PTO clutch apart, and the rear bearing out, and no motor on the front..ANYONE ? PLEASE ?
JK2
09-18-2006 06:03:31
 Re: 5 star PTO in reply to AC, 09-17-2006 18:07:26
You have to undo the lock washer from the nut at the front of the PTO clutch, loosen the nut, loosne the clutch adjusting ring completely, remove the cotter pin from the allen screw on the rear of the inner clutch hub then remove the allen screw. There is also a key that keeps the clutch hub from turning on the shaft that will need to be removed (between the inner and outer clutch hubs). The shaft can then be bumped rearward using a block of wood and hammer on the front of the shaft.
John
