Exhaust Manifold for UTS (KE 821 G)
John
08-06-1998 13:17:47
I am in need of an exhaust manifold for a 1946 MM UTS with single head. The casting number on the manifold is KE 821 G. I have found a used manifold with casting number KE 821 F. Could someone tell me if this is the same manifold or if it is different.
Todd Markle
08-06-1998 19:34:12
 Re: Exhaust Manifold for UTS (KE 821 G) in reply to John, 08-06-1998 13:17:47
: I am in need of an exhaust manifold for a 1946 MM UTS with single head. The casting number on the manifold is KE 821 G. I have found a used manifold with casting number KE 821 F. Could someone tell me if this is the same manifold or if it is different.
From the way MM part #s run I would say that the sufffix "F" indicates that this manifold is from an
erlier tractor than yours with suffix "G". Usually
parts with the same main part # are interchangable
but the part with later suffix has some improvment.
I am also fairly certain that all of the U series manifold
are interchangable from the red faced U to the UB special.
