Minneapolis Moline Tractors Discussion Forum
g1000 speeds
705
11-27-2006 16:15:35
was wondering what is out there for different combinations to speed up a 1000, ring and pinion, bull gears, out of other models? 50 series, wheatlands? any help would be great.
thanks
Moline_guy
11-29-2006 05:18:59
 Re: g1000 speeds in reply to 705, 11-27-2006 16:15:35
I think an easier option would be to go with taller tires, our vista had 18.4-38 on so they did make the 38 casting, if you could find these 38 cast centers then you could get 20.8-38 rims from a salvage yard and pick and choose on the tires, there are some tall 20.8-38 tires available. If you are running 18.4-34 or 23.1-30 now the 20.8-38 will speed you up a lot without messing with the gears. Also seen a 1355 once at a show the had 42" rears don't remember if he used the cast centers off a newer white or how he got those tall tires under it but that would definately give you some speed if you could get 42" rims on yours. Just my 2 cents, good luck.
705
11-29-2006 12:35:09
 Re: g1000 speeds in reply to Moline_guy, 11-29-2006 05:18:59
24.5x32 tire limit, just looking for some way to speed it up somewhere in the final drive end of things.
thanx
