Location of hydraulic filter on Ind. 500 tractor
Diesel Dan
08-07-1998 10:40:18
Please tell me where the hydraulic filter is on a Ind. 500 fork lift tractor.
Model MM 34780
Serial # 44395
mm
08-07-1998 12:53:46
 Re: Location of hydraulic filter on Ind. 500 tractor in reply to Diesel Dan, 08-07-1998 10:40:18
: Please tell me where the hydraulic filter is on a Ind. 500 fork lift tractor.
: Model MM 34780
: Serial # 44395
If this is related to a White forklift I was around the engine, transmission filters are ahead of the right rear wheel. If memory serves the engine one is the nearest one to the wheel and the transmission on is ahead of it. On mine they were the same screw on filter. You might as well change both filters while your in there. The front one is impossible to get to without removing the rear one first. Later
