Minneapolis Moline Tractors Discussion Forum
UB with 670 blocks and heads?
960
01-13-2007 16:38:47
I am new to MM tractors. A person wishes to trade to me a UB with what he says has 670 blocks and heads put together by a performance shop. Says it has 200 psi compression and it is too much for him to operate it. I have no interest in pulling but will it hold together with continuous running for antique plowing or should I stay from it?
Andy2
01-13-2007 20:50:32
 Re: UB with 670 blocks and heads? in reply to 960, 01-13-2007 16:38:47
If you are running LPgas it should be fine. If it's a gas engine, you'll likely have to run high octane or ethonal to prevent detonation. The other thing to check is the cam. If it's a stock U or 670 cam, no problem. If it's a pulling cam with increased overlap and duration, you could burn valves under continuos load.
