Minneapolis Moline Tractors Discussion Forum
GB LP trans.
bassndeere
01-22-2007 18:28:57
I have a 57' MM GB LP that will not go into 1st. or 4th. The rest of the gears are smooth and quite. Whats the problem and how do I fix it?
Thank you
LW
01-22-2007 19:03:23
 Re: GB LP trans. in reply to bassndeere, 01-22-2007 18:28:57
It could be the rail stuck, Or the gear itself on the top shaft. If you pull the top of it will be the center gear on the top shaft. ITs a duplex shifting gear the fork goes down between the 1st and 4th gear. THe rail is probably the problem.
bassndeere
01-27-2007 18:32:49
 Re: GB LP trans. in reply to LW, 01-22-2007 19:03:23
Hello LW,
Thanks for the information. Is there anything I need to watch for when removeing the top of tranmission case? Shifter in neutral? Special precautions when reinstalling cover?
Thanks again,
Don
