Minneapolis Moline Tractors Discussion Forum
Stuck Pistons
Anderson
03-25-2007 22:28:28
Trying to get stuck pistons out of a Z block. Any ideas???
will ia
03-26-2007 10:04:33
 Re: Stuck Pistons in reply to Anderson, 03-25-2007 22:28:28
I've heard once someone used hyd.pressure from a tractor. SOUNDS DANGEROUS TO ME.....
Anderson
03-26-2007 08:25:42
Have tried pressurizing the cylinder. Am not able to build pressure, leaking somewhere.
T.R.K.
03-27-2007 18:58:36
 Re: Stuck Pistons in reply to Anderson, 03-26-2007 08:25:42
Air pressure or hydraulic? You can get at least 10 times the pressure with hydraulic. I've used a lever type grease gun on the really stubborn ones.
The leak is probably at a valve. If not there and you can't see it coming out anywhere its probably cracked and the jug is probably no good anyway.
Duane Emge
03-26-2007 07:03:04
with the head on take a broken sprag plug and weld a grease fitting to it. install the plug in the head make sure the valves are closed and with a grease gun they will come right out.We had several stuck pistons in a R and a Z that came right out.It will work alittle quicker if you pack the cylinder with grease before you put the head on. It it will still take several tubes of grease.
8n dude
03-26-2007 06:43:45
i read one time that you can use dite orange soda pop . i told a freind about it and he got a wd allis . hope it helps
Bill Becker
03-27-2007 06:47:07
 Re: Stuck Pistons in reply to 8n dude, 03-26-2007 06:43:45
Orange pop only works on Allis. You will need Mountain Dew for a Moline.
Anderson
03-26-2007 06:13:39
Its going to take more than a 2X4
Burd
03-28-2007 09:15:38
 Re: Stuck Pistons in reply to Anderson, 03-26-2007 06:13:39
1. A buddy of mine filled the chamber full of grease. Bolted a steel plate with a grease fitting on top and pumped grease in it. Worked like a champ. 2. My father bought a tight (I mean tight) ZAU just a couple months ago. We made a jig that mounted to the connecting rod which had a 18" threaded connected. We put a old flywheel on the threaded rod put on a flat washer and nut and made a slide hammer. The ZAU is running today. I have a picture of it if you would like.
molinebob
03-26-2007 05:07:52
are the heads off of the engine yet, if so use a two by four and pound on the top of the piston and drive it down, It may take a few swings but it worked on mine, once it breaks free it shoud loosen up enough to pull them up the top of the cylinder. GOOD LUCK
molinebob
03-26-2007 08:52:56
 Re: Stuck Pistons in reply to molinebob, 03-26-2007 05:07:52
YOu dont just use a 2x4 alone, hit the end of it with a deadblow hammer, or even if a bigger piece of wood will fit in there use it instead. I am pretty sure I used a 2x4 on mine, but you could use whatever fits in the cylinder. If you dont have a deadblow hammer use a regular sledge hammer or what ever you have, the piece of wood will give before you damage the cylinder or piston. GOOD LUCK.
A/C Boy
03-29-2007 16:04:53
 Re: Stuck Pistons in reply to molinebob, 03-26-2007 08:52:56
Fill it with tranny fluid and let set a couple day and it should loosen up . I just did that with a 1941 that was stuck. It works
Fungus
03-30-2007 19:44:28
 Re: Stuck Pistons in reply to A/C Boy, 03-29-2007 16:04:53
I've used turpentine and it works well. I've heard people using tranny fluid too.
