Hard starting when warm
Alan H. Goettem
08-15-1998 18:59:51
I own a Minnie-Mo GVI deisel , and it stars really good and runs proper, after I have used it and let it cool down , then shut it off, it is a lot harder to get started when it is warm. Could this be an injector pump problem?
Diesel Dan
08-26-1998 20:13:34
 Re: Hard starting when warm in reply to Alan H. Goettemoeller, 08-15-1998 18:59:51
More than likely you're right on the money. Usually a diesel will easily start when hot. Failure to crank once hot is normally a worn out head in the pump. The reason for poor cranking is that the fuel is thin from heat, and wear in the head allows the pressure to escape before pumping out to the injectors.It's kinda like using a worn out bottle jack. It'l go up but you gotta pump fast.What can you do? Carry around a bucket of cold water to cool the pump off or have the pump rebuilt.Send me a e-mail with pump model # and I'll tell you more. Regards, Diesel Dan (the pump man)
Al
09-08-1998 09:02:12
 Re: Re: Hard starting when warm in reply to Diesel Dan, 08-26-1998 20:13:34
: Thank you diesel Dan, you were right on the money, our local injector service is taking care of the problem for us right now, Thank you again deisel Dan!
