### Prairie Gold Rush summer Convention ###
Ed
08-16-1998 05:51:11
At Greensburg, In. Aug.20-23 Come see 100+
tractors! bring your"s join the fun!
Greg from S Ohio
08-18-1998 07:02:14
 Re: ### Prairie Gold Rush summer Convention ### in reply to Ed, 08-16-1998 05:51:11
Where do I go once I get to Greensburg, IN? I am coming up I-74 from Cincinnati, OH.
Thanks for any info.
Joe Leising
08-20-1998 16:05:07
 Re: Re: ### Prairie Gold Rush summer Convention ### in reply to Greg from S Ohio, 08-18-1998 07:02:14
: Where do I go once I get to Greensburg, IN? I am coming up I-74 from Cincinnati, OH.
: : Thanks for any info.
Take ST Rd 3 south follow it to the fourth stop light turn left at the next street turn right from there you can't miss it.
be sure to go straight thru the first light and NOT follow old 3 to the left.
Have fun I'll be there with my R U ZB and 107 lawnmower
Greg THANKS!
08-20-1998 16:23:01
 Re: Re: Re: ### Prairie Gold Rush summer Convention ### in reply to Joe Leising, 08-20-1998 16:05:07
I am going to go Friday afternoon. I will be baling my third cut of alfalfa on Saturday.
I have a 1956 MM 445 Utility that I use for raking hay, pulling wagons, and light bushhogging.
See you there.
joe Leising
08-24-1998 19:00:54
 Re: Re: Re: Re: ### Prairie Gold Rush summer Convention ### in reply to Greg THANKS!, 08-20-1998 16:23:01
Sorry about the directions. The fourth light is a flashing light. It has been a few years since I have been down ther I hope you found it ok. I made it there early Fri. afternoon. I also pulled my tractors fri nite. Didn't do so well but I think someone might have helped me do poorly. I have used all of my tractors this summer to mow rake and bale hay with and have had no trouble with dirt in the gas. I filled my truck and two tractors from the same pump before going to the show. My ZB is a very consistent puller and "surprise" it has a lot of very fine dirt in the gas causing it to miss and cough terribly. I guess if you can't beat Minny you try to kill one.
Hope you enjoyed the show
joe
: I am going to go Friday afternoon. I will be baling my third cut of alfalfa on Saturday.
: I have a 1956 MM 445 Utility that I use for raking hay, pulling wagons, and light bushhogging.
: See you there.
