Minneapolis Moline Tractors Discussion Forum
tranny problems in my 707
bcguide
04-29-2007 22:01:43
I was out disking today, enjoying the weather and then my tranny goes tick,tick,clunk. The moter starts to lug down so I hit the clutch, stop, and try another gear. SOB the shifter is stuck and when I try the clutch the moter lugs down but no movement
any Ideas?
And wear do I look for parts for this old girl
Scott
rpllr
04-30-2007 15:27:51
 Re: tranny problems in my 707 in reply to bcguide, 04-29-2007 22:01:43
Curt is probably right, but I had the same problem on a R and it had a gear cluster locked up on the pinion shaft in the transmission.
Curt Cooke
04-30-2007 07:23:11
Scott, it's hard to say just what happened but it sounds like you're currently stuck in two gears at the same time. Get the cover off the transmission and give things a good look. If you're lucky the trouble is limited to the shifting pieces, the rails,forks,detents,etc. It may be that a gear has wandered from where it's supposed to be because of a broked snap ring on a shaft that's supposed to keep the gear in place. You can't know much until you open the top and have a look see.
