Minneapolis Moline Tractors Discussion Forum
Moline BF Decals
Anderson
05-14-2007 17:43:52
third party image
Where can I find a set of decals for a Minneapolis Moline BF like this one? I'm guessing these are the original because they still say Avery on them. Do they make these decals??? I have another picture of the entire decal in the tractor photos section
Glen in TX
05-16-2007 19:53:59
 Re: Moline BF Decals in reply to Anderson, 05-14-2007 17:43:52
Do a search trying to find Lyle Wacker or also might check tractordecal.com
Anderson
05-15-2007 07:16:48
The decal in the picture is from a BF that was on an auction that I did not end up buying and I did not write the serial number down from it. But I do already have a MM BF. The serial number on mine is R6856. I need to find a decal set for it. Would this one not have the decals that say Avery underneath MM? Thanks.
Phil Luna
05-14-2007 22:11:52
Contact Maple-Hunter decal,They will probly be your best source in having these decals made.There numbers are as follows John Hunter 812-894-9795, and Jack Maple 765-932-2027.I believe your tractor is probly a 1951 model when B.F.Avery was being changed over to Moline.I would like to know the serial number of this tractor too see if my idea is right,should be between R2749 and R2950 if I am right. Hope this helps.P Luna
