Minneapolis Moline Tractors Discussion Forum
block for avery V
44 massey
05-17-2007 16:27:39
Have a friend that is looking for a block or motor for an Avery Model V!! Thank You
Ill John
05-18-2007 04:44:17
 Re: block for avery V in reply to 44 massey, 05-17-2007 16:27:39
An Avery V should be an IXB3 which is a 3 gear engine.
T.R.K.
05-20-2007 12:05:38
 Re: block for avery V in reply to Ill John, 05-18-2007 04:44:17
The model V used the ZXB engine. I would suggest you call Bill Williams in Baldwyn M 662-728-3747. He helped me come up with a V carburetor.
Also, I have seen Hercules power units that used a magneto ignition version of that engine.
J Schwiebert
05-19-2007 07:48:08
The Avery A & R models used the IX engines. The V used the ZX as was mentioned.
Joe Leising
05-18-2007 05:18:49
I think the V used the ZXB engine. The Avery R/M oline BF/BG used the IXB.
Joe
J Schwiebert
05-18-2007 02:32:33
Where are you located? Is your block a 3 gear or 5 gear engine? Hercules made both. What is the problem with the old block? J.
ron99
05-17-2007 21:33:58
i have 10 hp herc motor
