Minneapolis Moline Tractors Discussion Forum
Steering housing for Uni
Alan K
06-29-2007 16:58:39
Does anyone have an extra steering housing with worm gear off of a mid to late 1950's Uni with powersteering. Just need the gear housing and stub shaft that goes in the housing ( complete unit goes in the pedistal ). Housing part number is 10A8859 I believe.
Mike Tessman
06-30-2007 17:41:21
 Re: Steering housing for Uni in reply to Alan K, 06-29-2007 16:58:39
Alan: Have the uni part and the M-5 housing. Only thing is that i live in South Texas. Shipping may cost a little. Call me at 830-254-3253. Mike
Alan K
06-29-2007 22:45:08
Also looking for a steering housing assy for M5 ( 4 Star, M602 ). Has anyone ever had one built up? Would like to have power steering, Im tired.
T.R.K.
06-30-2007 19:26:58
 Re: Steering housing for Uni in reply to Alan K, 06-29-2007 22:45:08
Alan, The 4-star front bolster won't fit your M5.
I don't know if the worm shaft/control valve interchanges betseen the bolsters or not, but if your M5 doesn't have power steering now it probably doesn't have the ram, the cylinder sleeves and the hydraulic tubing in the bolster now either. Your pump may not have the priority valve for the power steering circuit in it either.
It might be best to get everything-bolster, pump, control valve and all the tubing off a junker, if you can find one.
P.S. Are you still using the Uni on the farm? Someone asked me today if anyone was still harvesting with one.
Clint Youse MO
07-01-2007 05:26:31
 Re: Steering housing for Uni in reply to T.R.K., 06-30-2007 19:26:58
WE have an older uni with a picker on it htat we usually use to pick a little corn more play than actual use on the farm.
Clint
Alan K
06-30-2007 23:25:13
I do have power steering on the M5. Just didnt work completely. There are some worn parts I am replacing. Would like to take some of the "slop" up on the stub shaft. I am looking for a piston that goes in the hyd pump also, part number 35P289.
