9 Bolt hubs for UB
Diggerman
09-19-2007 17:50:57
Ok, Ive searched the archives and I know this has been addressed several times before. I need to find or build some 9 bolt hubs for my UB. I'm pulling stock farm, 5500 lb class. I want to mount 14.9-38's on pressed steel rims. I've read that some guys are using JD hubs and shimming them to fit. Others have talked about using Oliver hubs. I've even heard that you can use Case 400 hubs. Help, Please! Is there any aftermarket or custimized parts out there for me? I know that you guys are pulling the heck out of these old UB's and I'd like to add mine to the fun. Thanks!
Mopower
09-20-2007 04:47:54
 Re: 9 Bolt hubs for UB in reply to Diggerman, 09-19-2007 17:50:57
If you do a little searching on this MM forum there should be a concept picture of the MM 9-bolt hubs I will have produced before the turn of the year. Take a look and see if they would be something you would use.
Ethan Berry
The Mopower Ranch
517-243-0617
Gary from Muleshoe
09-19-2007 18:16:50
If you get an answer to this please email me. I have a UT I want to do the same thing with.
R Moline
09-19-2007 18:22:38
 Re: 9 Bolt hubs for UB in reply to Gary from Muleshoe, 09-19-2007 18:16:50
I'm not positive on the size of a UB axle but I think it is close to 3 1/8. If so we have a set of M&W 9 bolt hubs that we would get rid of.
