Minneapolis Moline Tractors Discussion Forum
445 / Jet Star center hood panel
Alan K
09-23-2007 09:27:31
Will a center hood panel from a Jet Star or 4 Star fit a 445? Are the side panels from 4 Stars the same as 445s? I may be in need of some parts.
JK2
09-24-2007 06:09:57
 Re: 445 / Jet Star center hood panel in reply to Alan K, 09-23-2007 09:27:31
The latch to hold the center hood down is different and so is the method of supporting the hood while it is open.
T.R.K.
09-24-2007 06:50:59
 Re: 445 / Jet Star center hood panel in reply to JK2, 09-24-2007 06:09:57
I made a 445 hood fit on a Big Mo 400. The original latch was already missing, so I just fabricated a latch assembly similar to what was in the Big Mo hood and had a friend weld it in with his wire welder. I also had to have a tab welded on for the hood support.
Some 445 hood sides have holes in them for the name plaques that were on the early 445 models. If your tractor uses a plaque, you will have to drill the holes yourself.
Kevin Moschenrose
09-23-2007 21:30:00
Yes Alan, those will all interchange with each other along with the Big Mo 400 as well.
