Minneapolis Moline Tractors Discussion Forum
Pins for 3pt hitch
Alan K
09-25-2007 18:10:49
Does anyone have any spare pins that connect the top link to the hyd reservoir for the 445s 5 Stars or M5s or know what will work? ( #10A10962 ). Can one be made of regular steel or does it need to be a hardened pin. I do plan on doing some plowing with it.
T.R.K.
09-29-2007 14:36:07
 Re: Pins for 3pt hitch in reply to Alan K, 09-25-2007 18:10:49
Is that the pin with the L shaped tab on the other end from the pin hole?
I've been just using pins from Tractor supply, but I don't try to make them work in the bottom hole of the yoke most times.
Alan K
09-29-2007 22:37:44
 Re: Pins for 3pt hitch in reply to T.R.K., 09-29-2007 14:36:07
Mainly looking for the one that would be considered the bottom pin on the top link that holds it to the tractor (on the pivot plate). They had a grove on each end for a pin to slip over, 1 inch shaft about 4 1/4 inches long. I would like to find one for the other end also.
