Minneapolis Moline Tractors Discussion Forum
M5 head cracked
Alan K
09-27-2007 21:05:55
I have a cracked head ( no... on the tractor ). It is a 10A4206. It cracked in the front in the middle on the outside. Is that a normal spot? The spark plugs on that head arent fouled up or look like it has an eternal leak. I may have to try some stop leak and keep an eye on it for the fall and then look at getting a replacement one. Anyone have a good pair of 10A4209s reasonable?
T.R.K.
09-29-2007 14:31:16
 Re: M5 head cracked in reply to Alan K, 09-27-2007 21:05:55
Well, if you have to have a cracked head, that is the kind to have. If it were mine, I would drain the water, clean the crack up, grind it a bit with a grinder and slap on some J-B weld. And try not to worry about it too much.
I've seen old repairs that seem to still be working. Right now both jugs on one of my Rs have been repaired with J-B weld and they are doing O.K.
