Minneapolis Moline Tractors Discussion Forum
1951 UTU PTO
Aberdale Farm
09-28-2007 17:25:00
I bought a 1951 MM UTU. After unsticking the engine, I've played with it a bit, but can't get the PTO to work. It has a lever coming out of the LH brake housing. I'm guessing it is an M&W quasi-live-PTO deal, but engaging the PTO lever under the seat doesn't seem to do anything.
Is something broken, or am I not doing something right?
Dale
Clint Youse MO
09-28-2007 20:55:25
 Re: 1951 UTU PTO in reply to Aberdale Farm, 09-28-2007 17:25:00
have to have the lever engaged and clutch forward the handle on the LH is a factory live PTo handle if the tractor will move it is fine
T.R.K..
09-29-2007 09:44:46
 Re: 1951 UTU PTO in reply to Clint Youse MO, 09-28-2007 20:55:25
The pto engage lever is just above pto shaft at the rear of the tractor. There is an L shaped rod with another bar or lever over it-most times, at least- to push it back and forth. Pushing it in should lock the shafts together. (But only when the shoulders on the two shafts align. It is not a plate clutch. Only a sliding collar joins the two shafts.)
If the tractor moves O.K., the live pto clutch is working. It only stops the ground drive when the handle is pulled, leaving the transmission turning along with the pto shaft.
