Minneapolis Moline Tractors Discussion Forum
Weight of an MM 4-16 semi mtd plow
Alan K
10-31-2007 10:53:48
Does anyone know the approximate weight of a semi mount 4-16 plow. It is a mid 1960s model with the cushion trip bottoms. I want to know if my trailer will handle it.
brian(MN)
11-01-2007 17:33:03
 Re: Weight of an MM 4-16 semi mtd plow in reply to Alan K, 10-31-2007 10:53:48
Alan, I don"t know what you have for a trailer, but a 4 bottom trip plow isn"t too heavy. If yours is a tamden axl, no problem, single axle should work if you have good tires. Is it long enough? If the owner has a loader , he should be able to pick it up and set it right down on your trailer.
Brian(MN)
