GVI Propane questions
NOHOG
11-23-2007 13:34:08
OK guy's I need help, I just purchased a 1960 GVI non running. The ensign regulator is missing but the guy threw in a continental regulator from a 705 he thought. Tractor still has the ensign carb on it. So my question is will the continental regulator work with the ensign carb, or should I use a continental carb? And if so what modifications will be necessary?
Another question on same tractor. the reason this tractor was parked(this is the story I got anyway) is because something broke in the throw-out on the clutch. When I got it home I removed the side cover and to me everything looked OK. clutch would snap in and out OK. But later I tried it again and it was extremely hard to snap in and out, just did not fell right, any ideas?
I will prolly have many questions as I restore this GVI but want to address these two issues first before I get to far on it. I want it to run and operate right before I tear it down.
Any help will be greatly appreciated, Thanks in advance
NOHOG from Kansas
ejr-IA
11-25-2007 11:35:08
 Re: GVI Propane questions in reply to NOHOG, 11-23-2007 13:34:08
Just read your post again yes I have the LP stuff .Live near Missouri Valley,IA.30 miles north of Omaha Nebraska on I29 .I will have to look and see what brand it is.
NOHOG
11-24-2007 13:37:54
 Re: GVI Propane questions in reply to ken in texas, 11-23-2007 13:34:08
What am I thinking, yes it is a century, not continental.
Thanks for getting me straight John.third party image
I did notice the small line on the ensign carb but couldn't find like fitting on the Century regulator.
Still scratching my head, trying to figure this outthird party image
Thanks for the suggestions, looking for more
NOHOG
Ill John
11-24-2007 11:43:04
I've changed my M670 over from Ensign to Impco, these 2 brands do not interchange, ie: the regulator of one will not work with the carb of the other. There is a "balance line" on the Ensign regulator to carb and none on the Impco. If you're not sure if it'll run, use starting fluid and leave the LP shut off. If it runs like that, turn on the vapor valve and see what you've got. Use the starting fluid sparingly. don't know anything about the "continental" regulator, was it by chance a "Century"? Thanks, John
335LP
11-23-2007 22:42:44
The other regulator should work if it's in good operating condition. Matching brands doesn't matter. What does matter will it regulate the pressure down to the 8-12 ounces most of them send to the carburetor. You just don't want to go with a regulator that came off a much smaller engine as it might not put out the volume needed to keep up. Going with a regulator that was recommended for larger size engine is okay as long as output is down enough and regulator works correctly. Maybe a bad throwout bearing on clutch?
LW
11-25-2007 20:11:09
 Re: GVI Propane questions in reply to 335LP, 11-23-2007 22:42:44
Actually they are pre-set diferently from the factory if you use a century regulator with a impco carb you have to change the spring in the regulator, and vise/versa.
335LP
11-26-2007 12:19:48
 Re: GVI Propane questions in reply to LW, 11-25-2007 20:11:09
Another reason to just go with all Impco because can't get most stuff for Ensign anymore after Bosch dropped them and split up. Impco is still in business today. I should have said some non matching brands might work if you know how or can make it work. Ensigns was always a pain when new. propanecarbs.com has some Century info and products.
ejr-IA
11-23-2007 15:41:50
I changed my GVI to gas didn't know much about LP and no storage for LP.Went and found a diesel hood and fuel tank and I already had a carb.The one I have has a 504 engine instead of the 425.
Ill John
11-24-2007 14:35:53
 Re: GVI Propane questions in reply to ejr-IA, 11-23-2007 15:41:50
ejr-IA, Do you still have the LP stuff? Where in IA are you located? My email is open. Thanks, John
