Minneapolis Moline Tractors Discussion Forum
1355 castcenters
1355 puller
12-10-2007 11:54:39
does anyone know if they made a light cast wheel center for a 1355 or a 2255 oliver.
Thanks
Freddy
12-10-2007 19:05:50
 Re: 1355 castcenters in reply to 1355 puller, 12-10-2007 11:54:39
the center with all the weight is the planetary. they did make 24.5 - 32 wheels for that tractor
m kuhns
12-10-2007 16:40:14
Yes, they did. We have a 2155 Oliver(G-1350 Moline) with 23.1x34 light centers no cast. I'm not sure what other sizes would be available. We made our own centers for 20.8x38's and welded them to the rim.
schrocky
12-10-2007 13:02:30
If I am not mistaken those tractors have the same rear as my 1350 and that is a planetary and you are pretty much stuck using what you have there
m kuhns
12-13-2007 18:15:21
 Re: 1355 castcenters in reply to schrocky, 12-10-2007 13:02:30
Actually the 2155 is the same tractor except with Oliver color. The piece that bolts to the planetary is cast weighing about 1000 - 1500LBS each. The rims on the 2155 are all metal that bolt to the planetary. They are about 3/8 to 1/2inch thick and then welded to the rim. I'm sure this was a factory option.
1755
12-11-2007 18:52:05
I have seen some 2255 that have what looks like a steel wheel bolted on there insted of the cast wheel but I dont know what is what there check out this site www.ipbc.net/oliver/oliver.htm it is the V8 Oliver site ask them they might be abel to tell you where to get a set hope this helps
